I have a 4" concrete slab (ground level) in good condition (poured about 5 years ago). It slopes 2% away from the house. I want to build a floating deck next to the home, it will be 23.5' x 22' (the slab covers most of this area, except the deck will extend 2 or 3 feet past this border on two sides, other two sides butt up to house). The finished deck height is 14.5", I have 3/4 IPE decking I will run perpendicular to the home (23.5' dimension). I have looked at few options to attach to the concrete:
1) Deck Block (pre-grooved for 2x material). It looks to have a 6" distance from slab to bottom of 2x material. If I use flush beams with 2x8 joists/beams, I would be at 14" finished height which I am okay with. I would then pour piers any area the deck protrudes past the slab. I would need to cut out the deck block to allow the 2-2x8 PT for the 3 beams
2) Use a Simpson BC ZMAX Galvanized Post Base. I don't see it recommended in any of the Simpson literature, but have seen a bunch of content where installers use these and anchor them to the existing concrete for low-level, floating decks. Again, I would use standard poured footings outside of the slab. There are heavier duty ones too I could use (E-Z Base Black Powder-Coated Post Base).
Any idea the best option here for connecting to the slab (in San Jose CA, don't get frost, so don't expect the slab to be moving, but would rather not attach a ledger to the home, just in case)?
Also, any guidance on the proposed framing for this picture frame deck (see attachments?) I am using 3, 2-2x8 flush beams, following cantilever, joist and beam guidance from the Deck Construction Guide (<1.5' cantilever on joist/beam, < 11'1" joist span and <5' for beam supports). I have some split beams on the drawing, but could just pay more and order 23' ft material, same for the rim joists. I'd rather split them, but get's a little tougher, rather pay more and make it easier...
Also note, the piers would be centered on the beam, just offset them so could see them in the 3D photo. I would attach them with the Simpson post cap. I assume I need to use 6x6, even for this low of a deck? Or could I get away with 4x4. Again, the guidance looks to be 4x4, but this is a really low deck.
Thanks!
Thanks!
