Call your local Land Use Office where they issue permits.I like to know if I can attach my ledger board by drilling thru the house brick and lag screwing it to the house rim joist. Thank you
Replace the posts, you can buy all kinds of trouble messing with a brick veneer.This deck is 26 yrs old and I am just having to replace rotten posts. It is a free floating now. If I attach it to the house I can eliminate replacing some posts. This fun all started because we want to redue the deck with composite
Brick veneer is real brick with wood behind it, the drain plane between the house and the brick is what I would worry about.Even if it is real brick
If using composite flooring you may need to beef up the floor joist to 12" OC.It looks like it stays free standing. Thanks
