This is my first post on here.I am planning to replace an old non ledger deck at my home. I have a couple of obstacles I need ideas on how to overcome.
1. The posts are round metal posts like a lally column only without the beam plate. Instead they have welded angle iron onto the post which the beams sit on sandwiching the post with 2 through bolts at each post.
How should I go about mounting my beams to the existing posts? I really would prefer to use the existing posts because due to code for freestanding decks, the footings must be at or below finished grade. I have a basement so if I were to replace the footings I would be required to dig nearly 8 feet deep on one side of my deck.
2. It is a freestanding (non-ledger) deck but code also requires it be attached to the home to resist lateral loads. I have brick siding which everything I've read says not to bolt through brick.
Any ideas, tips, hints, or previous experiences would be very helpful.
Thank you in advance.
