Hi, I'm working on a deck design. There are some wide spans, nearly 16' that I need to put a beam under partway across. Referring to the attached drawing the area south of the old retaining wall (brown dotted line) has about 3' of space under the deck and I can add a beam there no problem. However, north of the old retaining wall there is less clearance to grade and there isn't enough height to build a beam and rest the joists on it (its planned to be 8x2 PT Douglas Fir). How should I deal with this?
The way I have it drawn the beam north of the old retaining wall is effectively at the same level as the joists, and the joists are hung from either side of it. This would work structurally I think but might cause issues with drainage between deck boards that have a gap between them over the beam.
Any ideas or advice welcome.
