I have a double deck - the bottom is 5' off the ground, the top one 8' above it (both 12x18'). I am redecking both, and screening in the lower deck. A few questions. We need to seal the top. I have finally decided to stay with 2x6's - with 30# tar paper barrier between the joists, sloping outwards away from the house. Risky? It seems like it will work. It's not like it's supporting anything, maybe some running water. Their will be a wooden ceiling below that, that the paper will not touch.
For the lower deck, we're going for tile. Also risky, as the joists are 24" apart. The floor will be screened from the elements, and will get wet at times - not that it rains much in Atlanta. Would 3/4" ply be enough? Pressure-treated? What kind of spacing is needed between pieces? I can't imagine it would warp much, but will it flex too much for the grout, with traffic?
Thanks for any advice...
