Dead outlet
364 Views 3 Replies 3 Participants Last post by  freddyream
I’m a newbie and this might be a dumb question, I tested the outlet about 3 weeks ago. I tied it again and the tester threw a few sparks and now it doesn’t work at all. Can anyone point me in the right direction to fix this
Turn off the breaker for this circuit and then remove the receptacle from the wall. Post a picture without disconnecting the wires. If any of the wires fall off you likely found your problem.
Your (receptacle?) tester might be cooked.
A picture showing the rear of the receptacle would help. It may be the all to common case of a receptacle that was connected by the "back stab" holes provided for that purpose. It causes a lot of failures and isn't recommended.
Be sure to turn off the breaker to kill the power to that circuit before pulling the receptacle for inspection. Post a picture of the rear of the receptacle and also of the inside of the wall box would also help to make sure you aren't working on a multi-wire circuit before disconnecting the receptacle, if that becomes necessary. It's a safety issue.
Thanks for the response guys, I’ll take a picture of the back of the outlet when I get home from work. Thanks again!
