A circuit stopped working for me. A ceiling fan, a couple overhead lights, and a floor outlet are connected together. I plugged a power strip into the floor outlet and even though I had nothing plugged into it yet, the strip appeared to cause a breaker to trip. It is a new house to me and I am not positive which breaker is associated with this circuit. The labels on the box are mostly correct. I know which breaker it should be. I found nothing tripped in the breaker box. Reset all breakers anyway. Still no power. Reset the main service breaker that powered the entire box. Still no. Took the panel cover off and put a multimeter on each breaker and all breakers are showing they have power. Nothing appears out of order. Nothing hot or melted.
What can cause a circuit with several devices on it to fail if the breaker appears to be good and has power. Should I swap out the breaker that I suspect is the correct one even though I don't see anything wrong with it. I don't have a replacement breaker but I could temporarily steal one from a know good circuit to test.
Thanks for any ideas.
