1 - 20 of 53 Posts
Ordered and received a refurb tower via Amazon. Have used a couple months and it has an issue. Vendor tech dept. says needs to be replaced and can ship back at no charge. OK, no problem there BUT, the 'issue' is that the unit will not boot up at all, so I can not get into it at all, and on that hard drive is my password file with ALL my user names and passwords to various sites including banking, financial, and medical.
So, my question is: is there anyway to scramble or delete the data in this circumstance?
Also, I heard long ago that magnets can affect data on hard drives. Is that so?
You can get a device that allows you to remove the hard drive, put it in the device, and force read it. All it takes is a good strong magnet to scramble its brain.
You can get a hard drive dock and connect it up to another computer via USB and wipe the drive. But they probably want to have the operating system intact to diagnose the problem. So you might have to trust them. Sometimes that's all you can do. And you can always just change your passwords.
You say 'my password file with ALL my user names and passwords to various sites including banking, financial, and medical...is...on that hard drive'.
If it is a file for sure, like Word or Excel, it can probably be deleted.
Suggestion: Download an Ubuntu iso file and burn to a dvd. Then boot AND RUN Ubuntu from the dvd. Primer: https://ubuntu.com/tutorials/try-ubuntu-before-you-install#1-getting-started
There are probably commands beyond 'delete', even as an administrator, that will truly delete the file as in nuke the file. That way, as raylo has advised, Amazon's backend techies can still try to analyze what went wrong.
Discussion Starter · #6 ·
Will not boot up at all, as in entirely blank screen? Or will POST but not boot to OS (hang, like no MBR found)?
First time I re booted after registering Windows, the screen flashed 'can not locate operating system, will retry', or something like that. After about two minutes of that, I rebooted again, THEN just 'black screen'. ...... Only noticable difference was that the big fan (has two) would normally come on for 5 seconds at the begin of boot, this time it would stay on for about 30 seconds and then shut off.
Thanks Di, not sure I'm going to put that much effort into it (although had I known, probably would have been easier than what I did do), but I did call the vendor who is replacing the tower, told him my concern, he said 'don't worry about it, we will be wiping it anyway'. ...... I said "don't worry about it ...... easy for you to say". ..... He then suggested pulling the HD and putting it in my old PC as a 'slave', access the file and delete it ....... great idea ....... did it, but the old PC doesn't see it. Have booted a couple times, no luck.
Discussion Starter · #8 ·
After consideration, I figured I'd try it, but then I follow your link and what do I get.......questions, like "Download the Ubuntu release of your choice"....... "release of your choice"? ...... I haven't got a clue what MY choice is ........ I just like to see a button that says 'download'. But thanks again anyway.
Discussion Starter · #9 ·
There's probably 10 years worth of passwords and usernames, but yes, could change the money ones.
As for the OS, I don't care if I wipe everything, I think they plan on it anyway. And since I can't get it to read as a slave on my old PC, not sure if a hard drive dock would do any better.
But they say that they will be shipping the new one as soon as they can verify that the return is in the possession of Fed Ex, so not concerned with a total wipe.
Cheezy hackz. Did your tower come with a Windows install disc or do you have one laying around? Pretty much any version should do.
Go through the process of installing windows, making sure to FORMAT the hard drive(s).
Do that two or three times and no one's gonna recover that password file.
Can't tell if this is a hardware failure or a drive failure...sounds more like the former if there's a totally blank screen on boot.
OP, do you have access to another computer with SATA drives (assume the drive in question is SATA)?
Discussion Starter · #12 ·
Can't tell you if it is a SATA drive, but it accepted the connection on my old computer. As mentioned earlier, I tried it in the slave drive position but the old unit couldn't see it. Re booted a couple times but never showed in file explorer.
Discussion Starter · #13 ·
Thanks Mys, but don't have any boot discs. Found an old CD that I had burned called the 'Ultimate Boot disc', but didn't work. Apparently not so ultimate.
Discussion Starter · #16 ·
What's the boot order in BIOS? Is it set to boot the CD drive before the hard drive?
Excellent question. I'm not sure, just assumed that they were always programmed to boot from a cd if inserted before boot.
Unfortunately, without being able to boot it, there is no way I know of getting in to find out (at least at my level of knowledge). And if I could, I don't see any need for a boot disc.
Discussion Starter · #17 ·
So I received my shipping label, and am about to give up and ship it as is, although not thrilled about leaving that info on the HD.
Called a local shop, said $72 to wipe if I bring the HD. ..... Not spending that. Might as well just buy another unit and trash THIS HD with a drill.
· adam
If you posted the make model number of the tower, we can likely determine how to get into BIOS. Sometimes, using the BIOS/keyboard access methods, you can boot to a 2nd partition in the tower and reformat things using that method. But make model would be needed to research that.
Discussion Starter · #19 ·
Happy to give you that info, but my pea brain can't comprehend how one could get in to do anything when all you get is black screen and the unit shuts itself off after 30 seconds of trying.
Brand:Lenovo
Model: ThinkCenter M72e
As I said, it's a 'refurb'.
· adam
Black screen makes a difference, didn't know that. Without a screen, it's hard to do anything with that drive unless you remove it and put it into another tower or use an external housing and format with another computer.
I'll look for BIOS just for the record and post something later.
1 - 20 of 53 Posts
