Hi all
I've just bought a flat in an old flour mill whose walls are a barrier to a canal. There is damp on the inside wall from the floor to about 8" above the water level outside. It's beautiful but will obviously be a problem when it comes to decorating. The Walls are approx 18" thick brickwork and have been here for about 150 years. The brickwork is painted but not plastered, the bricks don't seem too moist but the cement? between them is loose to the touch. A stud wall that butts up to the brick is showing some tell tale signs of absorbing the water too. I can't drain the water so any ideas on how to address this problem?
I can provide pics if required
Thanks
Thanks
