Hi.
I pulled up my half bathroom's linoleum flooring to replace it with vinyl. The floor is concrete because we are at the bottom floor of a condo building. With the toilet removed, I can see that the hole in the concrete where the closet flange is seems to have a gap where concrete has broken away past the diameter of the flange and sewer pipe.
I was about to start putting down self leveling concrete on the floor but would like to know if I should repair this gap and if I should replace the closet flange?
If so, what method and material should I use for repairing the gap?
Just for extra info, the closet flange is 4" x 3" plastic and seems to be glued to the outside diameter of another plastic pipe, which is then on top of the sewage pipe.
Attached are pictures to show what I mean.
