I am about to install OSB on the interior walls of my new workshop.
My question is: Because I have several single and double outlet boxes in my new workshop, what is the best/easiest way to cut out the holes in the OSB over the outlet boxes ? Is there a router bit that can use the inside of the box as a guide to cut the OSB to fit over the box? I think there is a similar method that can be used with drywall, but I am not sure if there is a way to do it with wood panels. I think if I try to measue over and cut the holes before I put the panel up, I will miss the box enough to have problems (extra time/frustration/waste). I have experienced this with drywall.
