1 - 10 of 10 Posts
The short of it is: Can I cut existing metal joists with Shears? (The hand held, manual super-scissors, kind)
The long of it is: Condo. all metal joists. The washroom sheetrock is out 8" from the concrete dividing wall. I want to "sink" a 12" deep kitchen cabinet into the wall. That way it only sticks out 4" over the toilet, but when opened, you have huge depth for towels and the wife's junk... Trouble is 2 metal joists in the opening. :mad:
Anyway, I want to cut the hole exactly the size of the cabinet and push it in (smallest trim possible), so I would be happy if I can snip these joists, and be done. Otherwise its an 18TPI blade on the jigsaw and I'll need at least 3" of sheetrock clearance, top and bottom... Or the G-damned hacksaw. :cry:
Any help is appreciated
I really hope you mean wall stud and not floor or ceiling joist. Tell me you mean wall stud. If that wall is between units it may also be a fire wall. So you need to check to see if you can put that cabinet in a firewall.
Sorry, are they called 'studs' in the US? Ive only ever heard them called "wall joists" up here in Canada.
- Its a high-rise, city condo.
You are right about the fire wall thing. After I posted that I got to thinking that since that is a washroom that the 8" air space was probably considered a chase therefore the firewall rating was taken care of completely by the detailing of that concrete dividing wall.
Yep, in the US studs are almost always vertical members, while joist are horizontal members.
Not sure what part of Canada you're in, but here in Alberta they're well known as "steel studs" and yes tin snips is the recommended way of cutting them, even during framing. It's quick and no mess but watch the sharp edges.
once you cut the "studs" you have to make headers for the top and bottom of the opening out of the corrisponding size track in order to lock the cut ends of the studs in place. tin snips should work fine for this situation unless the gauge of the studs is thicker than 20 gauge. anything heavier than a 20ga. steel is hard to cut by hand.
Tin snips work perfect for vertical metal studs... just did that in my bathroom with $11 simple ones from Home Depot (then returned them...shhhh..). A couple things I learned after ruining one stud:
1) If the gap between floor and ceiling joist is say 8 feet, cut it 7'3/4" or a bit shorter... allowing for the joist movement as well as ease of getting it into the space...
2) on existing walls, adding a stud in can be difficult cause you don't usually have room to maneuver the stud into place/use a hammer to tap into perfect allignment... metal studs make it easy cause you can actually bend em a bit
3) like N0C7 said, REALLY watch the snipped edges... I grazed my finger along it by accident and sliced me pretty deep... take a stone or something like that and soften the edges if you will be working near the snipped part.
1 - 10 of 10 Posts
