You can cut cast iron with a sawzall with metal cutting blade or a snap cutter made for the purpose, but whatever you use to cut it, make certain that you have braced the cast iron from dropping down when you cut it.
All of the weight of the cast iron above the cut will be on it. Use 2x4 bracing if necessary.
Good Luck!
Mike
Good Luck!
Mike
