I need to widen this cutout by approximately 1 inch all around. The granite needs to be cut on both sides and the rear. The brick wall needs to be cut about 1 inch on each side as well to line up with the granite. I have to install this stainless steel shelf.
I think I can handle this job myself by renting a gas powered wet saw from homedepot. However, the largest blade only allows about 5 inches of depth. I suppose the brick does not need to be perfectly straight since the shelf has a lip. How should I go about cutting back the brick?
