I have some cast in a cottage that I need to cut out. There is actually a 4" cast stack that goes thru the roof with 3" vent.
I an getting a cast iron pipe cutter. I need some advice please.,.
I assume I should start cutting from the top and work down... Right? Cutting maybe 3' down from the top of the pipe and work my way down? I was thinking that if I cut from the bottom... I will have this heavy piece of cast drop on the floor.
Next... Can I use the pipe cutter on cast elbows too? I want to keep the cast piece that goes into the ground... But remove all the elbows above. Would a Stilsen wrench be able to break the lead sealant?
Thanks !
Thanks !
