1 - 20 of 28 Posts
The previous owner of my house had the electric upgraded to 220 service a few years ago. Problem is they have the new cable crammed up against a copper pipe. I want to move the pipe up so I can put new baseboard heater covers in the room above. I can't pull the pipe high enough to get the new covers on because of the stupid power cable. I'd like the cable below the pipe not above. What do you guys recommend? Whoever installed the cable is an idiot. I attached a picture so you can see what I'm talking about.
Thanks!
· " Euro " electrician
Thanks!
I have done the same thing when ran new service entrance cable like that and useally not a issue however if you really want to move the pipe the best answer is cut the eau pipe not the service entrance cable that is unfused so you will have to use two splices on the eau pipe.
Merci,
Marc
PS All houses are wire 220 from the incoming power line, it gets split in the panel box to 110 on each side.
They may have upgraded for say a 60 to a 100 amps panel or more but did not "change" it to 220 V.
· Licensed Electrician
I love it when homeowners tell me they have really messed up wiring because they can't figure something out.
Reactions: electures
Let them trying pulling a wire that size. I know I'd make it as easy on myself as possible.
That size is not bother me much but just wait until you see larger commercal / industrail conductor size now that will open your eyes on that one and you will be very sore when ya get done with it.
I just got one done yesterday 8 conductors per phase 240mm2 ( same as 500 KCM conductor )
Merci,
Marc
· Electrical Contractor
Merci,
Marc
That aluminum se cable I always find it to be really easy to bend. It's the URD cables and larger copper that I find are usually hard to bend. Most I ever get to deal with around here is 250 300.
What kind of puller do you use on a pull like that?
Discussion Starter · #12 ·
Thanks for suggesting going the route of shark bites. I figured it would be easier to cut the pipe than have a electrician come out and disconnect the cable. Maybe the person that installed the cable wasn't an idiot, but they sure didn't use their brain. It seems like having the hot water pipe free to move above the cable instead of pinned down against the foundation would of been the better option. The hot water pipe has begun to melt the outside jacket of the cable.
· Banned
Actually Paintrunner, it is the other way around. The Copper pipe came before the electrical. So really whoever pulled that service cable is the idiot, not the person from who knows when the house was built, installed that copper.
Probably more expensive than the pipe. But you could always price out both ways. The only deal with the heating pipe you will want to make sure that the antifreeze solution is still strong after you remove the fluid and pressurize it again.
Looking at the pic again that pipe will be squeezing the wire against the wood all the time and since heating pipes expand and contract all the time it don't sound like a good idea. I would add some elbows and go over the wire to clear it and leave some room.
1 - 20 of 28 Posts
