The bi-fold doors in the attachment rub along the carpet too much and you need two hands to move it. It also falls off the track because of this. I need to remove about 1/2" of the bottom of the door to allow it to move freely. If I use a circular saw (may rent from HD) do I need to be concerned about cutting a few inches up because I'll need to salvage the bottom of the door and reinsert once making the cut or can I just cut exactly 1/2" off the door and then reinsert the screw on the bottom into the already existing hole that will then sit on the track? The doors are 6 1/2' tall. The bottom of the door is not finished so I'm not concerned about a paint job on the bottom edge.
I adjusted the orientation of the picture but for some reason it still displays sideways, sorry.
