Hi -
I have a Coleman generator - PowerBase Series, Model PM 0542000.01. It is 2250 Watts, 120 Volts, 18.75 Amps, single phase – that I want to hook up to a Reliance 30216A transfer switch. The transfer switch has 6 switches and is rated for 120/240 volts – 240 volts are achieved by using switch 3 and 4 tied together. I'm going to de-couple those and only use the circuits as 120 volts.
The transfer switch has 4 wires for input – Green (ground), White (neutral), Red and Black.
The generator has 2 standard 3-prong outlets that you would normally plug an extension cord into.
My question is: I'm going to plug 2 extension cords into the two plugs on the generator, so how do I wire the outputs from the two plugs on the generator to power the transfer switch? I think it's like this:
A) Connect ground from plug 1 to ground from plug 2 then connect this to the Green (ground) wire on the transfer switch.
B) Connect neutral from plug 1 to neutral from plug 2 then connect this to the White (neutral) wire on the transfer switch.
C) Connect the Hot from plug 1 to the Black wire on the transfer switch.
D) Connect the Hot from plug 2 to the Red wire on the transfer switch.
Is that right? Does anyone see a problem with doing it this way?
Thanks in advance!!
- robojoe_fl
Thanks in advance!!
- robojoe_fl
