Hey all,
In an effort to keep it very simple, say I want to just drain my washer outside into a huge rain barrel that's 12 feet lower than my washer/first floor. That barrel is connected to a gutter downspout that's only a few feet away from my washer.
There's a bit more to the story than this like what I'd do with the greywater, but that's a different story.
95% of the time, I'd still use the house drain as usual. But 5% of the time, I'd want to switch from the house drain to this new drain barrel.
Since the downspout is only about 8 inches through the laundry room wall, I figure I could just cut a 2-inch hole through the wall, then cut a hole in the back of the downspout. Then run a downward-angled 2-inch PVC pipe right through the wall, and about an inch into the downspout. Then silicone/seal it all up.
Where the PVC comes into my laundry room down by the floor, I'd put a 3 foot high, 2-inch PVC riser pipe on it and attach it to the wall.
Done. When I wanted to use this instead of the house drain - I'd just lift the J-hook drain hose off the house drain and hang it on my new drain pipe.
No trap on the new drain - I figure since it's only used a few days a year, it would dry out anyway. Also figured I could put a valve in my new drain pipe to act as a closure. That would prevent frogs/critters, etc. from coming up the downspout into my house. I'd just open it when we wanted to use it.
Any problems with this idea regarding the flow of water?
Somehow, I feel like I'd want to use an automotive clamp to seal tight the j-hook drain when I was attached to it - so there is 0% chance that somehow, washer drain water could back up and flood my laundry room. I'm not sure how it could - but it's on my mind. No sure if it needs that air gap (like my house washer drain has) to vent air.
