I have built a 1amp 7.2volt power supply and i'm wondering if it will be able to charge a
7.2volt 1600mAh battery.
please help me.
Thanks In Advance.
please help me.
Thanks In Advance.
Well, yes and no. How are you regulating the voltage? How are you preventing the battery from overcharging? What type of battery is it?I have built a 1amp 7.2volt power supply and i'm wondering if it will be able to charge a
please help me.
Thanks In Advance.
A nickel metal hydride cell is pretty delicate when it comes to charging. You can't just hook it up to a power supply and let it charge. The charge must be controlled by a circuit that can sense when the battery is approaching capacity and shut off the current.I am trying to charge a 7.2v 1600mAh nickel medal hidride 5 cell battery pack and i'm using a variable switch which can take the power supply down to exactly 7.2volts. i have been told that the power supply produces 1 amp and the battery is only 1600mAh.
I'm not quite sure how to stop the battery from over charging, is there a little relay or something that will do it?
