You will most likely have to make your own mounting block with the back side cut to the radius of the column. I would then inlet the face of it to accept a pancake box.
Depending on how you are planning to wire it, you would need a hole thru the block, or combination of hole and a slot, to allow the wiring to be run into the pancake box.
