Hi there,
I recently built an aquarium LED light which went pretty well, however i read that I need to include a current limiting resistor into to the circuits.
I basically have used a constant voltage supply outputting at 12 volts and then ran 4 sets of series strings running in parallel with each other.
I am using a combination of cool white, royal blue and standard blue 3 Watt LEDS. I know that each LED will receive 4 volts each. So I did not include a resistor as this is about right for the LED as the specs of each essentially the same. However since building the light I have read that you always should add a resistor with any LEDs, however I can't see why this needed as I don't need the voltage dropping at all? I also read this was to limit the current, however I can't see how this works and obvious it seems more efficient not to include resistors?
Could anyone clear this up for please as I don't want to blow anything.
Oh the the specs for the LEDs are here :
http://stores.shop.ebay.co.uk/Future-Eden
The type of driver is like this
http://www.ebay.co.uk/itm/LED-Strip-Light-LED-Driver-Power-Supply-Transformer-AC-110-240V-DC-12V-/221245007918?pt=UK_Home_Garden_Night_Lights_Fairy_Lights&var=&hash=item33833ae82e
Many thanks in advance for anyone takes the time to reply.
Best regards
Jack
Best regards
Jack
