I noticed my front door rubbing in the top corner across from the hinges about 2 yrs ago. I made some adjustments to the jamb on top and on the side which took care of it for a while but the problem is still there. I now have a crack in the drywall above the door which starts at the door and goes upward with the widest part of the crack at the door. There is a large window to the side which also has a similar crack in the drywall above it. Neither crack is very large. This area is in an addition to the house where the old garage was. Suspecting some sagging in the whole wall across what used to be the garage door opening I placed a nail 6" above the floor on both adjacent walls in the corner. i then pulled a string across the room and marked the string line on the wall at mid span (the wall is 13'-8" wide). I expected the string line to be about 6 1/4 to 6 1/2 inches above the floor indicating the floor was sagging about that much. Low and behold it was right at 6". I'm thinking that what I have to do now is move the jamb upward on the side opposite the door. First I have to remove the adjustable threshold. I don't remember exactly how I put that in but I'll get it out and then I plan to remove the jamb nails and shim the jamb upward .
Anyone have any ideas about those cracks or guidance on this little problem?
