Hi
I solved my motor problem, and I posted the updated fix, but I'm very curious as to why it now works.
Please only respond if you actually know the answer.
I had a 3hp 220v single phase motor that would only try, but not start when plugged into a 20 amp outlet controlled by a 220v 20amp breaker. When I just replaced the breaker with a 30amp the motor started and ran fine.
Just another note, I had had the same thing happen with a 3hp table saw a while ago, same solution.
In both cases the breakers were not tripping, but the motors would only try to start.
Thanks in advance for your answers.
