BeN
I run 2" PVC (OD) for vac lines for a living. I also plan to run tracpipe through my rim joist and outer brick veneer for a BBQ gas line. Whenever I penetrate a rim joist I bore dead center and use a 2 1/8 or 2 1/4 self feed bit. I gebnerally fish LV wire through the same hole so 2 1/4 gives me a snug but not tight opening. I then silicone around the pipe.
When I sleeve this gas line I will bore the same way and likely extend the pipe with a sweep 90 elbow (vac pipe term for gentle curve, on either side) so as not to allow the gas line to kink.
To keep my vac pipe elbows flush to the wall at exit point I always countersink about 1" at my exit hole by going oversize 1/2" in diameter. This is in order to hide the joint in the counster sink hole and then I silicone. Esthetically pleasing and easy to clamp that way.
By countersinking I also keep the original bore close to air tight inside and eliminate wobble when glueing from opposite sides of the wall.
I don't know if your area has code for thickness of sleeves. Where I live I am told there is no code but it's worth checking with the gas company.
Also check if you use the elbow trick, to see if your piping is UV resistant for exposure to sun. Some pipe yellows and gets brittle in sunlight, I suspect the new PVC used for furnace exhaust pipe is more UV resistant than vac pipe.:thumbsup:
