How do you handle crown molding when a high window is in the way?
I've attached a picture of a possible solution and the molding I'm thinking of using. It's 4 5/8" crown with a picture rail set below it.
My thought is to run only the crown molding across the top, with returns on the picture rail so they "fall" into the window. The crown molding will probably hang down into the window by 1/2" or so. Would something like this look right?
