I have a run of about 2 feet of Crown Molding (tray ceiling) as per the photos below where I want the "End/Butt" to have a nice "End/Butt" where I have a piece of Crown Molding, but I can't figure out the angle cuts.
The tradition way of cutting a 45 degree "crown molding" cut (ie see the "watchjanedrill" video where she shows you how to cut a "outside" Crown Molding corner) does not work (trust me I tried) and to get to where I am, I have had to cut a weird "acute" angle on the green piece that was probably about 60 degrees instead of 45 degrees. This should be a simple
miter cut but I can't figure it out. The "white" painted "tiny" piece that is going to be the "butt/end" is cut using the traditional way (45 degree) angle the way "seejanedrill" tells you to in the video below.
Any ideas or suggestions?
Here is the "seejanedrill" video that helped me perform the 45 degree Miter cut for the tiny white Crown Molding piece in the photos:
