Hey everyone!
I'm having a problem figuring out a solution that is both practical and visually appealing. I’m hanging 3 ¾” crown that’s available at the local big box store in a bay window. I’m set on the miter saw angles, but the inside corners of the bay are rounded over instead of nice, sharp corners like in 90 deg. walls. The angle to try and cope the back of the crown seems almost prohibitive to try and do that. I’ve tried a test piece where I use biscuits and glue on the butt ends, but there is too much of a gap under the crown where it meets the wall. Has anyone done an inside corner similar to an outside bullnose corner? I thought about applying taping compound under the crown, however the walls is a darker color and the difference between the crown and wall would be magnified. Ideas?
Thanks in advance.
Thanks in advance.
