Ok, I know there are thousands of videos out there. I've seen a lot of them: sounds good, looks good, then the guy just says, "...set to 45" and off he goes. As if every corner is just that.
So, at the risk of opening Pandora's box I've got some questions here.
I'm new to hanging crown.
1. I already own a Dewalt DWS780 with crown stops. I plan on getting an 80tooth or so for the moulding;
2. I have a starret 505p-7;
3. I have a room;
4. I have 2.7" 50/38 crown.
5. I'm not trusting myself to use my coping saw just yet, so that's out of this thread.
6. I'll be using segments of 2x4 ripped to make backing strips along the wall in sections--probably not the entire wall's length though. I've been told that size trim doesn't really need it though.
7. no glue.
8. 16ga 2.5" nails on the gun
Q's:
Q1. if you have a compound saw you're putting in a mitre angle and a bevel based on the spring angle, correct?
Q2. After you cut the mitre, where do you position the wood to cut the bevel?
Q1. if you don't have a compound saw you're using crown stops and putting in a mitre angle only, correct?
Q4 .Is that the same angle if you are using crown stops?
The reason for Q4 is the Starret has an arrow that points to SINGLE-CUT but using the above angle gives (correctly) 50 on the miter but "10" for the single cut. Does an index of 10 on the saw's deck (with the crown tilted to its angle with stops) give the proper bevel that way?
It's amazing how many videos and pdfs (including the very one from Starret) that don't mention the other side of the dial.
Thanks for taking it slowly.
3. I have a room;
7. no glue.
Q's:
If you have (example) an 80deg inside corner. That's a mitre of 50 (90 - 80/2).
