1 - 7 of 7 Posts
I have a mwbc where one is running my kitchen outlets, and the other is running a dedicated circuit for the disposal. the breakers are adjacent in the panel, so they are on opposite phase and share a common neutral and ground. I was updating the outlets and so turned off only one of the breakers. when I tested the line to make sure it was off, my voltmeter still read about 10 volts. Is this normal? there were no appliances connected to either circuit.
Yes, that sounds normal. The combination of a high impedance meter input and inductive coupling in the AC wires causes this. If you were to plug a lamp into one of your kitchen outlets while the breaker is off the voltage should disappear as you are placing a low impedance path from the hot to a grounded conductor.
It is good practice to turn both breakers off when working on a MWBC.
Semi-Pro Electro-Geek
For sure! A MWBC is NOT DEAD unless both breakers are off.
Reactions: SD515
Super Moderator
I thought MWBC circuits were to have ties on the handles by code? At least thats what you guys taught me.
Depends on the code cycle when installed.
Discussion Starter #7
thanks
thanks for the assurance. this house was built in 1976, so at the time no breaker bar was required.
thanks again.
1 - 7 of 7 Posts
