I have come across access to scrap pieces of granite from a countertop installer. He said I can have all that I want because he just buries it in the ground.
I had a thread with all my plans and ideas in it, but it was too much. So I'm breaking down a couple at a time for anyone to comment on.
Idea 4
I would use a couple larger pieces to make some kind of outdoor table or planter type thing. For example I have one piece that is about 28" wide by 24" long. Gorgeous almost perfectly square cut piece. I thought of just framing a small table from wood, or trying to bend and weld rebar. I'm concerned about the weight somewhat and the chance of the table flipping over has to be nill cause it would break your foot.
Idea 5
One of my friends suggested using granite chunks to mosaic the seat of my perimeter benches, but I think the weight would strain my deck framing, and it would be a lot harder than even a wood topped bench on your bottom. So, feel free to comment, but I'm thinking this is a bad idea.
Idea 6
I was trying to think of things I could do with this beautiful stone that is otherwising going to be wasted, and pushed in a hole and buried.
I thought of building a large outdoor fireplace. (Yes, the installer has told me that I can get all of his scrap I want. Most of it is small chunks the size of your foot, or a shoe box, or longish strips 6 to 8" wide and a ft to 3ft long.)
On the highest end, furthest from the door, and adjacent to the corner where the gazebo will go is where I thought of building this fireplace/firepit. The deck surface will be about 20" off the ground. The nearest point of this fireplace would be about 4 ft from the back of the fireplace thats part of the house. Its a vinyl siding house.
My plan: Pour a 4" concrete pad, the size of the fireplace. It would be about 4ft front to back, and probably 6 ft wide. I'd nail the size down obviously before I pour.
Use cement blocks, and some mortar, and build up the "skeleton" of the fireplace from the pad. It would probably come up to about 4 or 5 feet above the deck surface. I'd use these granite countertop chunks, different sizes, to cover every visible surface of it. even the inside of the fire box would be a wider slab across the bottom, and the sides and top also built up. I could flare out the sides from the fire box, so the flames reflect lots of light off the gorgeous stone all the way to the edges.
I could either do a short chimney, or slant the roof of the fire box to direct the smoke out the back side, leaving a small rear opening at the top of the fire box on the back for smoke to exit.
I may even design it with the idea of adding gas in the future, though it would have to be an LP tank cause there is no gas on our street.
Would this idea work? Would chunks of 1 1/4" granite be too heavy to mortar to a block face? Would the whole thing be dangerous with its weight, or the fact that it would be sitting up next to the deck?
I would design it so that the actual fire box sits a couple feet back from the deck, with a "hearth" extending just to the edge of the deck and then maybe another foot of stone "hearth" actually sitting on the edge of the deck. (Minimize sparks hitting my wood deck.
Any suggestions or ideas???
Thanks for reading my post.
If I can clarify anything, please let me know.
Deck Plan. You can see to the left is where the fireplace would go. To the right is the grill with the granite chunk countertops.
Idea 4
Idea 5
Idea 6
