I want to start planing the construction of my server room and I'd like it to be very secure and hard to break into. Just wondering if anyone has any ideas?
I don't have much metal working tools (welding etc) so anything metal will probably be hard to do, but if that's the only way, I'm willing to learn.
As for wood I have most of the main tools of trade at least when it comes to framing. I've never actually did it before but it can't be that hard, I tend to just pickup this stuff.
What I'm thinking is to do standard walls but space the studs every 4" instead, so if they punch a hole through the drywall they can't physically get through. Each stud will have rebar on each side that will be strapped in somehow, so a sawzall blade or other cutting tool will have lot of trouble going through.
For the door, I'm not sure yet what I want to do, but definitely not a standard door as the only thing really protecting a standard door lock is two little screws at the latch. Even a metal outside door can be kicked in pretty easily. So I will probably custom build something. I also want to make it part of the wall. Basically I'm thinking some kind of rotating bookcase idea, but I'll probably go with something that slides behind the wall as it will be easier and require less clearance. On the inside of the server room where the 4" space studs are exposed, I will build another wall but make it standard spacing, enabling me to put fiberglass insulation, this is mostly just for sound proofing. I'd double the drywall too. Now for the sliding door locks, I'm thinking some kind of solenoid system that is activated from a hidden location in the house. I'm thinking a small panel with like 10 buttons, and they have to be in the proper on/off configuration for the solenoids to lodge themselves in the right position for the door to open. Basically like lock tumblers.
Any other ideas or comments on what I've come up with so far?
Idealy I just need the room to be as discouraging as possible to get into, and have them give up and just steal something else, if they've made it into the house. If the room is concealed well enough they may not even realize there is a room there at all.
