I just purchased a 2 family home, and the previous owner installed a tub that creaks when you're showering. Apparently this is caused by not having the proper (or any) support underneath it, and will slowly lead to cracks and eventual failure.
I have access to the tub from the basement through a 6" hole cut in the subfloor for the drain. Additionally, I was going to replace the floor (yes, FLOOR - vinyl floor in the bathroom) so I don't care to rip that up and see if I could sneak something underneath from the side.
Is it possible to fix this properly with the tub still installed, or should I be looking at removing the tub to fix this? The surrounding wall is also drop in, so I can't just remove a few tiles to pick this up.
