1 - 8 of 8 Posts
Hello,
The inspection of a home I am considering revealed two posts that are pretty far off center on their pillars in the crawlspace (see pic below). Of the many posts and pillars in the crawlspace, these are the only two that are off and it looks like it was just a construction error and not due to the house shifting, etc. These posts are below the laundry room near the garage.
A few questions:
1. How big of a deal is this?
2. Can it simply be fixed by buying a few post jacks from home depot and adding additional support for the beam on either side of these off-center posts? (Assuming post jacks are installed correctly - perfectly vertical and on reinforced footing).
3. If you answered "no" above, what's the recommended fix?
Thanks!
Uploaded with ImageShack.us
I don't think I have a pic of what is exactly above those posts...but here's another pic from the crawlspace that shows a better view of other posts. I believe the two in question above are no different than the posts in this pic.
Thanks!
Civil Engineer
Maybe you used a really wide angle lens, but the post to the right looks like it is way out of plumb. If so, that is a significant problem. As for the posts that are off center, it may be possible to install a new post centered on the pier more or less, and still hit the beam above. If so, that would be a good solution. The other thing about the posts is that they are bearing directly on the concrete pier, which is not good practice, they should be on a galvanized standoff plate such as the type Simpson makes. This will reduce the chance of rotting of the post at the base.
I cannot tell from the photo how the post is attached at the top, it should be attached using a special bracket, again Simpson and USR make them.
Thanks, Daniel. Good suggestions...when I get a chance to go back down there I'll take another look to see if we can add another post to center the load on the existing pier.
And you're right, that post on the right does look pretty far off in the picture. I'm pretty sure it's just the lens, though...neither the inspector nor myself noticed that when we were down there...and something that far off would (hopefully) be pretty obvious.
If you want to take a picture of where the top of the posts meet whatever they're bearing against lay on your back, and try a couple of " pics" from
that perspective - go to the other side of the posts and give us a shot from there.
If you're using a "flash" on your camera - consider adding another "light-scource" (along with the flash) - to increase definition, and remove shadows.
rossfingal
1 - 8 of 8 Posts
