Yesterday I wasted half a day on trying to pressure wash my backyard patio, pavers, fencing and walkway...
I'm a new homeowner (previous home was a brick townhouse with a tiny backyard and deck, so no real maintenance/work needed). New house has a half an acre in back and a 1/3rd up front. Concrete patio, a stone side 'patio' (not sure what to call it, but it's not a simple concrete slab but about 20x12' of square pavers?), driveway, some pvc fencing, and a concrete walkway that wraps from back patio to front driveway.
All are pretty filthy from no power washing over the years. I first bought a $99 electric power washer from Lowe's and tried that but, after 2 hours of use, it would have taken about 20 more hours just put a dent in the dirt due to the low power.
So I returned it and went to Sears and they had a floor model (ie, used) 2550psi Craftsman for $203. Came with everything and appears new, but when I got it home I saw that the previous owner did put oil in it. He/she put too much (it's well above the 'full' dot on the dipstick). I filled it up with the recommended gasoline, set it all up, connected the hose, etc., put the switch to 'FAST/START' as stated in the manual, and tried to start it. About 40 pulls later my arm was too sore to continue and I gave up.
According to the reviews on the Sears.com site this particular pressure washer is a dog (had I known that I wouldn't have bought it). But considering I got it for $100 off normal price I'd like to try to get it started just once. If not, I'll return it tonight. Question:
Could the 'too much oil' be the reason it won't start? I don't want to tip this thing over to drain some of the oil if it is pointless. Any other recommendations to check?
Spark plug looks good/new. I pulled the plug wire off and no corrosion and looks like good contact with plug. There is no primer/choke on this model.
