Everything is in the title.....
And are the tools compatible?
I agree you got a much better deal price and quality.I went to HD tonight and noticed the B&D Matrix 20V was not properly priced...$69.79 for the drill + the impact driver head. It should have been $99 ($69.79 is for the drill/driver only)
But they honored the price displayed, and on top of that they took my 20% Harbor Freight coupon....So the set ended up at $59, tax included
However, on my way back from customer service desk to the cashier, I saw the Ryobi set for $99 (Drill/driver and Impact driver, 18V and 2 batteries included)..So I returned the B&D and took the Ryobi set, and the guy at customer service applied the 20% as well
1) This guy at my local HD was VERY nice
2) I ended up with a Ryobi set for $83, with 2 batteries and a 1/2 chuck drill driver
3) The B&D was "only" 1 battery (but 20V), and the chuck was 3/8 and not 1/2
4) So overall I think the Ryobi is a better set, but I don't know why, I find the B&D Matrix concept (or the Crafstman Bolt-On) seducing....!!!
Milwaukee makes a fantastic corded 7 1/4 inch circular saw.The 6390. FWIW I have a 6310 cordless milwaukee 61/2 inch saw. It uses V18 lithium ion or 18volt nicad batteries. Did well for the small amount if time I used it.french_guy said:OK, I trust you
So what would be a good corded circular saw you would recommend?
I just threw my Milwaukee 6310 cordless circ saw in there as a example of cordless circ that actually works. For heavy duty work you can't beat corded tools. For example when mixing driveway sealer, concrete, drywall mud etc or drilling 1 1/2 inch holes with a auger bit I use a corded 450rpm spade handle drill(Milwaukee 1663-20).french_guy said:Yeah, but won't be compatible with my Ryobi batteries !!!
Since corded tools are better for heavy use (Circular saw at least) I wonder if I shouldn't go with the B&D Matrix 20V set for all around house jobs, and buy more powerful tools for heavier jobs...!!!
I'm going to respectfully disagree on that one. I've had the Craftsman 19.2v 7.5" Circular for a while now and it's fine. It's the same tool as the Ryobi as they are both made by TTI. You do need a LiIon battery to get decent runtime and the runtime is limited but for what I've used it for it's been fine. Will cut sheets of plywood, 2x4's and bigger 2x lumber. We used it when I re-did my workshop and when we re-did the basement last year.Do yourself a favor and buy a corded ciruler saw not a cordless one.
None of the Ryobi ciruler saws are worth buying.
Just be aware you don't get the same warranty - for example on Milwaukee the CPO is 1 year while new is 5 years. Also the price difference is not that great. In my Milwaukee example new the batteries are warranted for 5 years. In that 5 years you will most likely need a new battery. That alone could eat your savings.Might also want to check out CPO tools. They carry a lot of factory reconditioned tools with factory warrentys and big savings.
