Hi there, just finished a 6 month major reno and have been in the house for almost a month now. In the last two weeks or so we noticed that the ceiling paint in the shower was beginning to crack. We figured this was due to ventilation issues as the ceiling vent had not yet been vented all the way to the outside. It is now and we have noticed no new cracking or peeling on the shower ceiling. Now we just need to touch it up.
However, today we noticed that a spot on the wall has begun to crack as well but much worse. The ceiling cracking was small but this is much larger (pics to follow).
A little background. The entire house was badly nicotine stained so we TSPd the walls, and after proper clean up primed the entire house with BIN primer to cover the stains. The house is also a concrete construction with original plaster walls. However, in the bathroom we replaced most of the plaster with the proper drywall for bathroom conditions, except the small section of wall that is now seeing the cracking. I believe it was oil based paint underneath as well.
We will obviously need to sand, crack fill and repaint. Just looking for suggestions on what paint to use, and any tips to ensure this won't happen again.
Thanks in advance for your expertise!
Photo 1 shows the wall area that is cracking
Photo 2 gives a reference point for where in the room this is. It's right above the picture on the wall on the right hand side, closest to the shower. A side note, the paint between the shower and the spot in question is fine.
