1 - 1 of 1 Posts
Hi Folks,
I purchased a house last year with a sidewalk along the side to the back (where there is a walk up basement). Unfortunately, the sidewalk was laid too high above the foundation next to the brick vaneer and it cracked and sunken towards the house.
I was told by my neighbor that this is actually the second sidewalk that was laid. And you can indeed see that this stretch is a different colour than the rest.
So I ripped out the sidewalk (which had two steps next to the driveway at the foundations lowest point).
Upon removing the sidewalk I discovered it was poured directly on clay soil. So I dug up a bunch of that and laid crushed gravel down. I have also graded it so the two steps are now split up and rise with the foundation.
I have a mason coming to fix the brick work and after that will have a new sidewalk poured.
What I want to know is what I should put next to the side walk to allow water to follow away from the house? The neighbors grade is much higher than mine.
I though of digging a trench along side the newly poured sidewalk, putting a weeping tile or pipe of sort and covering it with gravel. Is this a good solution? How deep should the trench be? How far should the trench go? To the public sidewalk? To the street (under the sidewalk?).
Thanks
1 - 1 of 1 Posts
