Hi there,
My recently purchased 1960's property has a number of cracked sub-floor joists (perhaps 50% look to be damage-free). A pre-inspection builders report didn't mention them, and a subsequent visit by same builder says the cracks are normal for New Zealand rimu timber and it's not a problem. I'm not so sure. The damaged joists typically look like the one in the picture below, some are worse. The bearers are steel I-beams on concrete foundations. They look fine. The joists are 9x2", length approx 12ft, spacing 18". They are herringbone-braced twice per span.
The arrow indicates a gap above the joist between it and the partition wall above, which is essentially being supported only at its ends. I'd appreciate any comments.
Thanks.
Thanks.
