1 - 13 of 13 Posts
Hello all,
I'm in a bit of a bind: we're about to start the process of finishing our basement (poured concrete foundation). It currently has a crack a that leaks a trickle of water during severe storms.
We have a company coming next week to seal the crack. Yesterday, however, we had a nice storm drop 3" of rain down, which revealed several concrete ties that were also leaky (nothing accumulating on the ground, but the dampness was obvious.
I can improve exterior grading to an extent, and the gutters already flow away from the house.
I'm tempted to install a dimpled membrane and drain it under the slab: it seems like a ton of work, but it seems like a nice insurance policy short of digging up the foundation and fixing the exterior.
What are the thoughts here? Is that necessary? Or would fixing the tie leaks be enough?
I was planning on using closed cell spray foam as well...not sure if that is compatible with the membrane, or if the foam will provide water barrier itself.
Another idea was putting small weep holes into the slab, applying spray foam insulation; and installing a sump pump? (There's about 8" of gravel under the slab)
Super Moderator
The only proper fix is from the outside in my opinion. No point in letting the water in and then getting rid of it. Stop it on the outside.
Discussion Starter #4
I agree, that would be ideal, but it's so cost prohibitive at this point, I'm not sure we could do it: with gas, water and sewer lines entering the building its difficult to use mashinery to get the work done.
Plus, it would require new landscaping, new concrete (walkways), etc.
Discussion Starter #5
"I'm tempted to install a dimpled membrane and drain it under the slab:"
Can you explain this statement a little further?
It seems most of the waterproofing companies in our area use this particular technique, and charge an arm and a leg for the labor involved.
Essentially, you break up concrete around the perimeter of the floor, and dig down next to the footing. You add a perforated pipe, and slope it towards a simp pit.
You back fill with gravel, then apply what is essentially a thick piece of plastic with dimples on it over the gravel, and up the concrete walls, securing it at the top. You apply concrete over the plastic to finish the floor portion.
Basically, the idea is whatever water enters the foundation is directed below the slab, and pumped out. It almost acts as a band-aid protecting the wood.
I don't get tons of water now: maybe the equivalent of a small bottle of water spilled, but it's still enough to wick up into any studs.
Master General ReEngineer
Yer lookin' at dumpin' a Ton of money inside with the drainage ditch,...
What's outside the house along that wall,..??
I agree with the others, ya deal with water Before it's a Problem,...
Yeah those systems have been around for a while now, and as you say they cost an arm and a leg.
Discussion Starter #8
On the exterior wall with the leaks I have a front entrance with poured concrete steps, a water main, and dozens of plants/bushes
Discussion Starter #9
True, but it's work I can easily do myself.... It's just labor intensive.... Breaking up all that concrete, hauling it out, and then lugging dozens of bags of concrete mix back down....:
' an arm and a leg ' is fair otherwise we wtrproofers would all have small boats :laughing: we do this work every week :thumbsup:
for what the op described, i'd suggest injection w/hydrophyllic polyurethane but realize injection's more of an art than a science :yes: still & all, a competent diy'er can successfully do it,,, emecole's got good materials, they're diy friendly, + love to talk you thru problems.
in general, its more labor-intensive AND costly to excavate & waterproof :furious:
Ayuh,.... So is the grade pitchin' water into the foundation,..??
Are ya waterin' yer plants, 'n causin' the problem,..??
Is the concrete that's there, pitched the wrong way,..??
Is the water main Leakin',..??
Movin' bushes is a 'ell of alota easier than draggin' tons of ruble outa the cellar, 'n tons of concrete back down,...
Discussion Starter #12
Here's my dilemma: I have a guy coming to repair and re-inject a leaky crack tuesday already. Prior to this massive rain-storm, it was the only source of water entry. I'd be more than willing to have him inject the leaky ties that appeared, but I'm afraid of what happens when we get a 4"rain storm? Will it seep water in other places???
The epoxy I'll trust to the pros with the tools. If I'm putting up a plastic membrane: I'll rent a 70lb hammer, and do the grunt work to save $5000
Discussion Starter #13
The grading could be a tad better away from the house, but it's a bit difficult: the house is on a hill (raises about 8 feet over 30 feet from the street.
I'm wondering if maybe even putting an exterior french drain a few feet down would be a solution to my issue
1 - 13 of 13 Posts
