I had a slab poured over a garage floor about 3 1/2 mos. ago.
Details:
The garage is 20'x10' 5"
The floor was raised 5"
Form: 7 sheets of 8'x2'x2" styrofoam bead board was used to reduce weight, rebar drilled into original slab and bent over, #10 remesh.
I noticed today that the slab has a small crack extending almost all the way across the 10' width (see imagaes).
This area will be a living space. I haven't decided what kind of floor I will put down. Should I be worried?
The small image is a crop so that the crack is viewable. The dark gray lines in both slab images were editied in for clarity.
Thanks for any comments.
Mark
Details:
Mark
