There is a vertical crack that starts in the mortar of the front brick panel wall surrounding our fireplace insert. A friend mentioned this may be due to heat expansion.
There is no movement in the brick at all, even when applying a lot of pressure. Is this a situation where you chisel out and replace any cracked mortar? Should the brick be filled with colored mortar as well?
https://drive.google.com/file/d/1DPjvqN09jZU1UcSroUzeTPy3va-4F5R0/view?usp=drivesdk
https://drive.google.com/file/d/1DYIPI78DcLmcFF-ghbrQX3SXpfFQ0J3z/view?usp=drivesdk
Here are some photos to reference. Any help is appreciated.
