Here is my issue... Central NJ, we had about a week of steady rain. Noticed wet floors in partially finished basement (non-finished areas are bone dry).
Had gutters that were clogged terribly and running along foundation where water was found in basement. Water was also settling near expansion joint in driveway, where it meets my foundation wall. The joint had basically erroded, so I used a closed cell backer rod, epoxy and sealed the joint completely.
I cut back some of the drywall in the corner of my basement where water was present. Have been shop-vac'ing the space (in what appears to be a floating slab) between my concrete blocks and slab for over a week. The cut portion around my slab looks to be about 6 inches deep... I can actually see the water coming in from what looks to be a cracked chunk of concrete. I've thought about using a hydraulic cement to patch the spot, but I'm assuming this will just force the water to another section of degrading block, etc.
Biggest question mark now is: where is all this water coming from? We havent had rain in a week. I've emptied at least 70-80 gallons of water from this section of floor/wall. No exaggeration, the trips from my basement to garage to empty a filled 10-gallon shop-vac. I'm thinking water has entered and filled many course of my block foundation or a pipe is busted underground somehow. I know the water-table is high in my area, but with only one corner of my basement getting wet I would assume this isn't the answer.
Thoughts, ideas?
Not sure if we can post pictures here, but will do if possible. Just bought the house in November, what a friggin nightmare!
Thoughts, ideas?
