Hi all,
I got an idea from a friend for building a box to disinfect items coming into the house with UV-C light. I've done a lot of research to figure out how to build it and how long it takes to kill coronavirus with UV-C.
The way to do it is to build a box, lined with aluminum foil and install the lights. The box needs to be sealed so no light leaks out. UV-C is very dangerous and can burn skin and cause eye damage. Some bulbs produce ozone as well.
I have purchased two 8W Germicidal bulbs but I am confused about how I need to use them. They are the size of a small T5 base fluorescent bulb. Do you know if I can use them in a standard 8W fluorescent fixture of do they need a special fixture with blast?
I really want to figure this out and then spread the word.
