The title should be "reducing air return size"
I'm doing some major remodeling. I am removing a load bearing wall that has a 6x24 return duct mounted on the wall on the ground. Since I will have an island overhang right above it in these new plans, I plan to save some work and not move the return air. It will just be converted to a floor register. Being under the island overhang, it will be aesthetically pleasing and will still function, but I want to reduce the size to make it less noticeable. Can I do that if I plan to cover up a couple of supply ducts. My thinking is that it will balance out the airflow. This is all in the main living space.
