I am building a back-bar in a closet area for a previously built bar. As you can see from the pictures, I am using reclaimed wood on all of the walls (both in and around the back-bar area). The cabinet is just being used as a 'place holder' to get the correct height. I intend to build-in cabinets that will span the length of the opening and contain the kegerator shown. Due to the large amount of wood surface(s), I am trying to decided what else I can use as a counter top and color suggestions. I am concerned that simply staining / painting wood will be overkill. I am looking for suggestions that can be completed on the less-expensive side that will maintain the rustic, weathered look of the walls.
