1 - 8 of 8 Posts
My creaking body won't tolerate much more of hauling supplies from the boat dock to the cottage. I intend to lift groceries, diesel fuel, construction supplies, firewood, and other items, and also send things back down to the dock as well. (Something like a tram for freight) The vertical rise is approximately 20' and the horizontal run is about 65'. I doubt that the per basket load would be more than 500 lb. I would like to build a trolley and winch system of some type, relying on wood supports up the hill rather than steel. I am considering using some type of winch system that can be operated in both directions, from either the dock or cabin end. I have electricity to operate the system. Any advice that anyone would have would be most appreciated, including the type and capacity of a winch that would reliably work, how to design the "tower" supports, how many I would need, and the optimum way to pulley and cable it. I also need something that would reliably work in the winter at cold temperatures. Am I being too optimistic about using wood supports, or do I really need steel?
Thanking anyone who can help in advance, greyskies99
· Haverhill Trade 1965
A picture might help. My first thought was a commercial garage door opener if you could get a long enough chain or cable. That would only need the buttons at each end and could probably be mounted low so it wouldn't need towers
Thank you Duckweather and bbo for your interest and quick reply. I have posted a picture of proposed routing which is to the right and parallel to stairs. You will note that the first part is a cliff, so I don't think skid or wheels will work. I was thinking of an ATV winch as well, that might work. I don't know how much power a garage door opener would have, but I hadn't thought about that solution. Any thoughts about towers or supports?
Kind regards,
greyskies99
1 - 8 of 8 Posts
