Banned
Using old work boxes I have mounted timers to control bathroom fans.
The plate for each timer sticks out from the drywall surface 2/32" or 3/32".
Is there a gasket that is made to fill this gap?
Anyone else have this problem?
Caulking is not my first choice to solve this.
The plastic old work boxes? Yeah, most old work boxes make the device flush to the wall. And some plates are very small. I like the P&S unbreakable plates, they should be enough to cover the gap you are talking about.
I don't know of any gasket, but there might be.
Picture?
I know exactly what you are dealing with. A different cover plate may help. The nylon plates we use seem to have a little more depth than the oldschool ones.
If that wont do it, try to tighten the box more so it sucks into the drywall a bit.You might even have to use your razor knife and take out a tiny bit of the drywall paper.
Be careful.
Banned
Be careful.
Yes, I think I'll abrade or cut away some of the drywall surface so the box sits farther into the wall.:thumbsup:
