Hello.
I was hoping to get advice on how best to fasten corrugated metal to rafters.
This is for a gable-end awning that extends out about 14 feet from the gable. We have 2x6 rafters every 22 inches. I'm not sure if I should lay out 2x4's across the rafters perpendicularly or if I should sheet the whole surface with ply or possibly even t1-11. (t1-11 would give it a nicer appearance from below.
My main concern is getting enough bite when I screw through the valleys on the corrugated and into the underlying wood. But I don't want the screws to break through and be visible from below.
My preference is to use 3/4" T1-11 for the best appearance from below
Thank you very much.
/ug
What wind zone are you in?
I would put 2x4s perpendicular to the rafters, either between or on top of the rafters. Then I would put a ceiling on the bottom of the rafters.
Thanks OT. That's a good idea. I can even use a much thinner and lighter material on the underside as it should get any weather.
I'm in SoCal, inland so I think that's Z1. It's also located in a canyon lower than the surrounding land.
Thanks again!
