A friend of mine is redoing her garage into a hot glass studio.
She wants to put up corrugated metal panels as the interior walls for fire purposes.
She wants in insulate the walls-I am unsure on this. There will be kilns and a glory hole inside. These reach internal temperatures of anywhere from 0 to 2250. I am not too sure she will want the insulation. Hotter than blazes in the summer. The fall is good weather but the winter is best. My 2 arguments/concerns: 1)temp and 2)the concept of moisture.
Once the insulation is figured, then the next question would be vapor barrier. I think she has wood siding although I am not sure. Would the metal benefit from a vapor barrier, or would her siding? Remember constant fluctuations of temp.
And the last....I am trying to figure out if there is a way to mount the metal right on top of studs. If they are 18 on center and it depends on what metal she can get etc....but say it works out or we cut it to work out....is there an insert to put in the arch to sit flush atop a 2x4 or should i just use washers and flatten it atop a stud?
If anybody has experience with metal benders like the siding or gutter guys use, would that be in anyway helpful to crimp ends of metal for corner fasteners?
Thanks for any advice!
